Hello every one.
I'll start off by listing my setup.
Numark Cue
Dual Numark iDCX's
Rane Empath Mixer
I bought the Empath about 2 months before I decided to go digital. Now I am wanting a mixer that will run the internal mixer on CUE. It's not needed I guess, but I want to be able to record my mixes with out using the knob on the icdx as the cross fader.
I haven't had good luck with the Numark boards. Thier mic input is way to noisy for me.
I spent the big bucks on the Rane mixer because I wanted the best around. I would hate to take a huge loss if I sell the mixer, but like I said, it would be nice to have a USB mixer also.
Let me hear your thoughts.
Should I keep the Empath and suffer with the knob crossfader on the icdx?
Should I purchase a new USB mixer and take a loss on the Empath?
Numark Cue
Dual Numark iDCX's
Rane Empath Mixer
geposted Mon 24 Sep 07 @ 11:52 pm
Just bumping this up for some help.
geposted Tue 25 Sep 07 @ 3:30 pm
I'm not quite sure what you're asking to be honest. The Rane is a nice mixer. Are you talking about fading videos and having to use the ICDX for that?
geposted Tue 25 Sep 07 @ 4:50 pm
what I am looking for is a USB mixer that will controll the internal mixer on Cue.
geposted Tue 25 Sep 07 @ 5:05 pm
U mean like a controller??? how abt total control etc?
geposted Tue 25 Sep 07 @ 6:12 pm
Something like this but works with CUE and not Scratch Live.
http://rane.com/ttm57sl.html
geposted Tue 25 Sep 07 @ 6:37 pm
the Ecler NUO 4 is used by people on these boards. Search the forums, I'm not sure if it has been successfully mapped yet. I personally don't see the benefit of controlling the internal software mixer when you have a hardware mixer. You have a very good mixer in the Empath. If it was a video thing I understand wanting to control the video fader with a midi device but you can do that a lot cheaper with the x-session or a Hercules console rather then a brand new midi mixer.
geposted Tue 25 Sep 07 @ 8:59 pm
- Ecler Nuo4 and Nuo5
- Korg Zero4 and Zero8
- Pioneer DJM700 and DJM800
- Allen & Heath Xone3D
and a few more...
geposted Tue 25 Sep 07 @ 9:27 pm
Thanks for the help all... looks to be more of a PITA than it's worth.
I'll just use the know on the iCDX to controll the internal crossfader.
geposted Tue 25 Sep 07 @ 9:46 pm
Numark DXM-01USB is a great mixer
geposted Wed 26 Sep 07 @ 12:13 am
i'll check it out....
Does it controll all the kill switches too?
Also, is this a plug and play unit? or will I need to map the controlls?
I never had good luck with Numark boards though. The mic channel is so loud... (hisss)
geposted Wed 26 Sep 07 @ 1:01 am
Jeremy - I don;t think anyone told you this:
Numark USB mixers are NOT midi - are just Usb SOUNDCARDS embeded in the mixer. They are just mixers that have a non asio (non timecode compatable) soundcard
To have a mixer that controls the interface it must be a MIDI mixer.
Look into Ecler.
Look into Ecler.
geposted Wed 26 Sep 07 @ 1:36 am
wow, Yeah that was a huge overlooked factor.
Thanks a lot for the info... I'll be keeping the Empath then.
geposted Wed 26 Sep 07 @ 1:38 am
so what mixers ARE timecode friendly, cause I'm mostly familiar with Numark and Pioneer mixers, haven't heard of these other brands
geposted Wed 26 Sep 07 @ 4:25 am
