Hi
Any suggestions when i put a non stop mix on play (,Deck A or deck B) After about 5 min into the song it goes to silence but it is still playing just no sound
Thanks Musicmatch
Thanks Musicmatch
geposted Tue 25 Sep 07 @ 4:28 pm
Which version ?
What is your Max Load setting ?
What sound card ?
What sound card ?
geposted Tue 25 Sep 07 @ 4:36 pm
Hi Cstoll
I am useing Version 5 But i have also tried 4.3 Sound card Maya ex 5 setting Max load always.. When just playing normal songs not a problem only when i load huge file etc 60 min plus
geposted Tue 25 Sep 07 @ 5:39 pm
Nobody seems to be able give me a solution to this problem..
geposted Tue 25 Sep 07 @ 8:45 pm
musicmatch wrote :
Hi Cstoll
Probably a memory issue?
Try max load none, see if it stream plays well
geposted Tue 25 Sep 07 @ 8:48 pm
Tried no luck very strange only non stop music files ? single files no problem the deck is turning just no sound
geposted Tue 25 Sep 07 @ 8:54 pm
okey, try this :
- Set max load to ALWAYS
- Drop the large file at a deck.
Does the wave info for the songs build show for the whole song?!
If not, your memory will not load/decode the large file into memory, or is doing it too slow.
If it loads REALLY slow after first initial part, try turn on SpeedLoad with Dj CEL's registry tool, from the download section
geposted Tue 25 Sep 07 @ 9:06 pm
As u mentioned above i dont see the file load ...Thought that might be the problem will registry tool .Thanks
geposted Tue 25 Sep 07 @ 9:11 pm
If the file doesnt load completely (build a song graphic wave for volume in skin), when max load is set to always, its a problem with your ram most likely.
If you have a pretty new PC, with good amounts of ram, and a pretty new clean Windows, try a VDJ reinstall , just to make sure all is right.
geposted Tue 25 Sep 07 @ 9:14 pm
Got enough memory pretty new machine have not tried reinstall ... but when i analyzed the files again .. then opened up vj5 loaded the song only loads half of it,plays what is loaded then silence again
geposted Wed 26 Sep 07 @ 2:41 pm
