Are there any skins for the V1.02 virtual dj apart from the default and advanced that come with the softwae?
I've tried downloading and installing some from this site but i just get error messages, are they not compatible?
geposted Wed 27 Oct 04 @ 6:21 pm
https://virtualdj.com/download.html
There is a more recent demo version than the 1.02.._.version
you use.
This version is compatible with the skins you download.
Regards.
you use.
Regards.
geposted Wed 27 Oct 04 @ 6:57 pm
1.02 is an outdated, and no longer supported version.
If you are still using 1.02 you will certainly be shocked and amazed when you finally step up and try the latest version.
I recommend that you completely uninstall the severely outdated version that you are using, and download the latest trial version. (or of course you can always purchase it) You will be quite pleased with the progress that has been made in this software over the past year.
geposted Wed 27 Oct 04 @ 8:02 pm
Thanks, Unfortunately the demo only lasts 20 days, so I would prefer to buy it. However the internet connection I have is very slow.
Is it possible to order a CD by post? I did not see this option.
geposted Thu 28 Oct 04 @ 9:42 am
