Not trying to spam here but seems someone would know the answer to this.
Here is the link to the other thread I started.
My question is this:
Substitute any sound card with multi outs. How do we do this?
Quote :
Running a single CD player with the total control. I have a splitter going to a separate channel on the mixer but want to use two separate channels for queing from VJ.
Do I split the signal again into the second set of inputs?
input 1/2 Deck 1
input 3/4 Deck 2
Output 1/2 Channel 1
Output 3/4 Channel 2
CD direct to Channel 3
How do I do this and run timecode?
On another note can you run a midi device while running the total control? I was not sure of this due to the Total Control being a midi device as well.
Thanks for any help with this. Still a rookie but still loving the software. Still teh greatest ever...
Why in the hell did it take me this long to give in and try it?
input 1/2 Deck 1
input 3/4 Deck 2
geposted Wed 26 Sep 07 @ 5:09 am
Paulie_C -- there is plenty of information on the forum to answer your questions - you need to search for MAYA and Timecode
Also, have you looked at the guides section - https://virtualdj.com/support/
geposted Wed 26 Sep 07 @ 4:11 pm
check your previous thread I answered you
geposted Wed 26 Sep 07 @ 4:16 pm
