where can i buy cue timecode vinyl?
geposted Wed 26 Sep 07 @ 5:42 pm
I asked that already...but no answer.
geposted Wed 26 Sep 07 @ 5:44 pm
You can order from ANY dj shop that carries the Numark brand, or directly from your national or local Numark branch.
www.numark.com
geposted Wed 26 Sep 07 @ 6:08 pm
Depends where you're at too.
www.pssl.com
www.pssl.com
geposted Wed 26 Sep 07 @ 8:13 pm
will the vdj ones work out of the shop here? can i buy from the uk?
also i take it its $20 for one and not a pair.
geposted Fri 28 Sep 07 @ 3:35 pm
Yes it will as it is the same with numark tcv although i not sure if from here (site) it is gen 3.
geposted Fri 28 Sep 07 @ 4:57 pm
i don't understand? when gen do i need.????
please someone tell mei have a timecode vinyl for pcdj scratch. it doesn't work. the mp3 download burnt onto cd works. but i'd like the vinyl to try.
geposted Fri 28 Sep 07 @ 7:41 pm
Check pssl to see if they'll ship internationaly, they have the Numark TCV for $15 a pair;^]
http://www.pssl.com/bitemdetail.tpl~waGroup1datarq~NUM01~eqint_KeyIDdata~47992~itemNumber~I00-3%20%20%20%20%20%20%20%20%20%20%20%20~UID~2007090517311683~disp_IMG~Y~catgroup~%5BcatGroup%5D
geposted Fri 28 Sep 07 @ 7:45 pm
You can buy them online in Europe too
http://www.thomann.de/gb/numark_virtual_vinyl_ersatzvinyl.htm ( ships to most countries - back in stock this weekend)
http://deejayladen.com/wg/hs/Numark-Virtual-Vinyl-Timecodevinyls_59602.aspx (ships most countries - back in stock in few days)
geposted Fri 28 Sep 07 @ 7:51 pm
