3 things:
Thanks to whoever made it! It's awesome!
Why can't I find it on the site anymore?
Is there a chance that a Virtual Vinyl compatible version is on its way?
Thanks!
Thanks!
geposted Sat 29 Sep 07 @ 7:43 pm
Dj Cel made it :
https://virtualdj.com/addons/view.html?type=video%20effect
geposted Sat 29 Sep 07 @ 8:03 pm
dj-in-norway wrote :
It doesn't show that it works with v5 is that correct to assume?
geposted Mon 01 Oct 07 @ 7:25 pm
No, It works if you are manually crossfading but not yet with automix, although [hint mode] Cel has said he's going to fix that in an upgrade [/hint mode]
geposted Mon 01 Oct 07 @ 7:54 pm
Thanks just downloaded it... I have a huge video show this weekend and I think it will enhance it. Sometimes I hate having to think which transition is going to give the best effect for intro video. Or I forget to switch transitions usually the case!...
geposted Mon 01 Oct 07 @ 8:07 pm
My personal favourites are the old satellite and Cels spiral, that spiral is just superb.
Also a quick tip, if you're going to use the random thing, have a look through your transitions first, as if like me you have some themed or event specific ones (wine glass, heart etc) you may want to move them into a seperate folder as they may not fit in with what you're doing.
geposted Mon 01 Oct 07 @ 8:19 pm
Not a problem... I don't have those transitions... but thanks for the tip. By the way, nice work on your video drops
geposted Mon 01 Oct 07 @ 8:33 pm
The new version of this plugin for automix works well (currently available in beta). I just need time to finalize it.
geposted Mon 01 Oct 07 @ 10:54 pm
SEE!!!! that [hint] mode WORKS!!!!!!!!!!!!! :o)
Cheers Cel, am waiting for that one.
geposted Mon 01 Oct 07 @ 11:48 pm
The same thing for sonique visuals would be perfect... *ahem :)
geposted Tue 02 Oct 07 @ 6:30 am
I don't understand, you can set sonique to slideshow so that it randomly changes anyway.
geposted Tue 02 Oct 07 @ 11:13 am
The plugin is now online
Enjoy ;-)
Enjoy ;-)
geposted Thu 04 Oct 07 @ 12:25 am
Thanks Cel, as you know i've been waiting for this one. Just hope you don't have to change it again when 5.1 comes out
geposted Thu 04 Oct 07 @ 1:01 am
So question, is their a download available that will work with Virtual Vinyl? My friend has both Virtual DJ and Virtual Vinyl and needs Random to actually work on Virtual Vinyl.
geposted Wed 17 Oct 07 @ 8:06 pm
There is n its available for pro user only;)
geposted Wed 17 Oct 07 @ 8:18 pm
Last night, I noticed that the new version only works with automix, is that correct. If that is the case I should have both versions, right?
geposted Wed 17 Oct 07 @ 10:41 pm
Okay so I changed my profile to reflect that I am a professional user (although a novice since it is really my friends), so can anyone point me to where I can download a version of the Random Video Transition that works with Virtual Vinyl since the one that ships with it does not?
TIA for any help.
TIA for any help.
geposted Fri 19 Oct 07 @ 12:53 am
HERE:
Nice job on the upgrade of the video transition plugin...
geposted Fri 19 Oct 07 @ 1:03 am
So, just that I understand. Will the video transition on this site work with Virtual Vinyl? All of the plugins say for Virtual DJ 4.x and higher. My firend has that as well, but does not like it as much as Virtual Vinyl......... TIA again.
geposted Fri 19 Oct 07 @ 4:10 am
