Atomix is displayed a white tag next to each song played. After installing VISTA ULTIMATE, all these tags have disappeared. It seems that it starts from scratch. However the internal database file is there and full of data. How can I get them back, because it is really helpful for me. Thanks for any help
DJ BRUNO - HANOI
DJ BRUNO - HANOI
geposted Tue 02 Oct 07 @ 11:34 am
Not sure if AtomixMp3 will work ok on Vista since it is not updated for so long, the Team will help.
geposted Tue 02 Oct 07 @ 2:51 pm
i will try this out , are you logged in as administrator?
geposted Tue 02 Oct 07 @ 9:32 pm
Thanks to all for trying. I found why. So please find here the reason. Under Vista <Program Files> located files modified are stored in another folder: UserName\Appdata\local\virtual store\program files\Atomixmp3. The Internal Database must be located there. If you cannot find the folder, do a Search on your disk and you will find it.
geposted Wed 03 Oct 07 @ 7:39 pm
