Every time I click a folder of music, it takes approx. 10 to 15 seconds to show the contents of the folder. If I have to grab a song quick in a pinch or emergency, this would bot help me. I just paid for this yesterday and hope there is a resolution for it - please advise
geposted Fri 29 Oct 04 @ 4:49 pm
It does take a few moments to show the contents of very large folders.
10-15 seconds tho?? What are your computer specs? and how many files are in the folder that takes 10 seconds to show?
geposted Fri 29 Oct 04 @ 6:18 pm
I had some delay only when i used a usb 2.0 drive connected
to a usb 1.1 port, and the parser enabled, but not 10 sec
this is to much.
If this is your case, try to disable id3 parser.
this is to much.
geposted Sat 30 Oct 04 @ 12:47 am
I guess it's the parser that was doing it - thanks so much for the info - all the feedback I got has been helpful - thanks again
geposted Sat 30 Oct 04 @ 9:27 pm
My techno/house folder is 19GB it takes almost 40 seconds to load up, how do I disable the phraser?
geposted Sun 31 Oct 04 @ 3:31 pm
