Hello,
I installed the multi_function 2.0 skin from this page. Unfortuately I clicked in the
skin on the lock symbol an get know messages on the screen and I can´t use the skin anymore.
Is there any possibility to remove the skin in the actual version?
Are there other skins available as on this page?
Thankls in advantage for your support.
Helmut
Helmut
geposted Wed 03 Oct 07 @ 2:18 pm
To unlock the Multi-Function skins -- click the developer's web address in the bottom left of the skin to unlock the skin.
If you want to delete skins - Go to --
Version 5
My Documents -> VirtualDJ\Skins and delete the zip file for the skin.
Prior versions
C:\\Program Files\\VirtualDJ\\Skins and delete the zip file for the skin.
If you delete the currently selected skin, then at launch VirtualDJ will automatically use the VirtualDJ default skin.
Version 5
Prior versions
geposted Wed 03 Oct 07 @ 3:43 pm
