If I use the stereosplit option in the soundcard-settings (master left, headphones right on a stereochannel) every mix I record is mono. This makes no sense, because the recording-stream should be grabbed right after the downmix of both "Turntable-Decks" and not after this audiostrems gets mixed down to mono to be send to the left channel. Or are the mp3s played mono in the first place if this mode is selected ? I think this is a bug, which really should be fixed.
geposted Fri 29 Oct 04 @ 11:11 pm
you always have a bug with crack.
geposted Sat 30 Oct 04 @ 3:44 am
is that so ? another good reason to cough up those 99 bucks. I cant use the demo since I obviously had it already installed some time ago, when I tried to run the demo it told me "testlimit expired" (or something like that).
geposted Sat 30 Oct 04 @ 7:39 am
you could always contact the e-service...
geposted Sat 30 Oct 04 @ 1:38 pm
