i have version 5.2 installed, but when i change the skin i want to use, it go's back to default skin on restart ...?
any ideas anybody
any ideas anybody
geposted Fri 05 Oct 07 @ 10:18 am
hi simon
i think your problem can be cured on start up of vdj, if you untick "ask me next time" then choose your skin in config next time you open up vdj it should come up with your default skin... hope it helps
Tayla
Tayla
geposted Fri 05 Oct 07 @ 1:30 pm
