Was setting up for a gig on Wednesday and "D:/ is full" popped up in VDJ 5-10 minutes after I started it. The D drive has all my music on it but it isn't even a quarter full. I just clicked ok in the box and reloaded VDJ. It did it again but I just clicked ok and carried on. It didn't affect anything in VDJ that night and I didn't notice any changes. Any reason why it would appear?
Spec
Acer Laptop (Can't remember the model)
Vista 32bit
Spec
Vista 32bit
geposted Fri 05 Oct 07 @ 4:54 pm
which version do you use ?
geposted Fri 05 Oct 07 @ 5:12 pm
Sorry, forgot to mention. Latest version. I've been using it for weeks without the popup, it was just on Wednesday it happened.
geposted Fri 05 Oct 07 @ 6:17 pm
Go to your D:\ drive and check the permissions for accessing the VirtualDJ Local Database v5.xml in the Root of the drive. Typically the message you received is because VirtualDJ thinks it can not write to the file because there is not enough space available to write data. In your case you maybe seeing the message because VirtualDJ simply can't write to the file.
geposted Fri 05 Oct 07 @ 9:09 pm
