Forum: VirtualDJ Skins
Topic: VDJsoftware not found
I was using V-Mix skin (1st version). Had a bit of a problem and deleted it by accident.
I downloaded it and tried to install, but received the msg
"VDJsoftware not found". I presently using ver 4.3. It did work previously with this ver.
Any ideas??
geposted Sat 06 Oct 07 @ 8:39 pm
the problem is that skin is designed for a very old vdj version
and the installer doesent know where to look ,
pm me your email adress and il send the zip file :)
