Hi guys
I've found this site with 99 plugin for sonique whats more it free....
http://support.xmplay.com/file.php?cat_id=6&count_per_page=5
Enjoy
Enjoy
geposted Mon 08 Oct 07 @ 4:56 pm
Some sonique doesn't work on VDJ, all the tested plugin is here http://www.virtualdj.com/forums/77828/VirtualDJ_Plugins/83_Sonique_visual_effects_for_Virtual_DJ_(Reload_pack_1_1).html
geposted Mon 08 Oct 07 @ 5:05 pm
Bad sonique may crash! Careful..:)
geposted Mon 08 Oct 07 @ 6:49 pm
cioce & spinna are right,
a post on the forums not so long back told one of these sonique pluggins will literally blow up on screen condeming the world and its masters and will crash your system, so only download sonique from the download link to vdj pluggins where they have been tested as safe to use, i think there's 82 or 83 now to choose from...
Tayla
Tayla
geposted Tue 09 Oct 07 @ 4:28 pm
I have tested most of these and found only one caused a problem. However this was on the free trial as I'm in testing the software before i purchase my copy and take it out on the road.
I do agree that it's best to use the plugins on the website and when I purchase the software i will, But as Virtual Dj Trial didn't have any of the sonique plugins I had to look else where While I testing.
Maybe it would be a good ideal if one of the plugins was available for testing.
The Testing is going great and it appears that Virtual Dj is the best on the market. just another week of testing then i'm going to try it live on Saturday night.
Mark
Mark
geposted Sun 14 Oct 07 @ 10:43 pm
Your smartest decision would be to use the tested and true ones that are here in the downloads section after becomig a pro member, after that I would go through those and narrow it down to the ones that run on your system with low cpu usage. I know there are quite a few i dont use as the cpu usage scares me:) Hope to see ya as a pro user soon:)
geposted Mon 15 Oct 07 @ 12:09 pm
i cant seem to get these to work in version 5 of VDJ?
just get the blank VDj video screen...:S any advice?
geposted Thu 18 Oct 07 @ 1:29 pm
At option
tick - use this plugin for audio file only - select sonique
n also enable hardware acceleration..
n there u have it;)
n there u have it;)
geposted Thu 18 Oct 07 @ 2:48 pm
Switching between Sonique and Slideshow plugins always forces VDJ to crash.
geposted Fri 19 Oct 07 @ 12:40 am
Yeh, i do that spinnaJ, but still get nothing...
used to work fine :S
geposted Fri 19 Oct 07 @ 12:57 am
Maleko , are ur soniques in ur correct folder? u must have it at my document vdj folder?
geposted Fri 19 Oct 07 @ 4:59 pm
My documents / Cue folder / plugins / video effects... Now go back into cue program / effects / sonique / open / select any vsp / open / activate / slideshow / slideshow slider somewhere in the middle for testing / bottom slider all the way to the left for max viewing.
geposted Fri 19 Oct 07 @ 10:29 pm
ah ok, so ive got it in wrong folder sicne its all chnaged, so where od the sonique folder go?
in My Docs > VirtualDJ > Video Effects > Sonique ?
or somewhere else?
or somewhere else?
geposted Fri 19 Oct 07 @ 11:49 pm
yes it should be placed there for easier use n referances.. but fyi it doesn't really matter where u put ur sonique file.. etc desktop.. as long as u open it from the effects section in vdj n activated it, you don't have problem.. but like i said previously, if u haven't put ur sonique in my document>virtualdj>plugins>video effects, it betta to transfered it there:)
geposted Sat 20 Oct 07 @ 7:57 am
ahh, cheers, all sorted :D thnks
geposted Sat 20 Oct 07 @ 12:56 pm
Great:)
geposted Sat 20 Oct 07 @ 1:47 pm
I've not had that problem - I was switching between Sonique, Slideshow and video all night last night?
geposted Sat 20 Oct 07 @ 7:38 pm
