When I load any of my ambient (no audio) video tracks, I get a VOB error, and the track will not play. Any idea on what might cause this?
geposted Mon 08 Oct 07 @ 6:06 pm
The error is because VirtualDJ can not find an audio track to load.
geposted Mon 08 Oct 07 @ 6:56 pm
Load no-audio ambient video clips in the new ClipBank plugin in the video effect section.
You can load up many ambient clips ready to be triggered there
geposted Mon 08 Oct 07 @ 6:58 pm
eric
are you loading these into cilpbank to play, if you are and still have problems do a quick conversion of ambients to avi/mpeg1. hope that helps
Tayla
Tayla
geposted Mon 08 Oct 07 @ 7:01 pm
sorry norway
couple of minutes in time lag there, will catch up with you one day lol...not
Tayla
Tayla
geposted Mon 08 Oct 07 @ 7:04 pm
hehe ;)
geposted Mon 08 Oct 07 @ 7:05 pm
I see the clip bank, but I have several hundred chroma key, billboard, and ambient theme videos that I will frequently alternate with music videos (My Hercules output goes to my main mixer, which is then mixed with my main music source - PCDJ). So I would like to browse and load these directly by browsing my assorted video folders, without having to go into effects. Is this not possible?
geposted Mon 08 Oct 07 @ 7:59 pm
Well, it should, agree..
Not sure why that hasnt been made, but as you say, sometimes the collection is too large to use the ClipBank for ambients.
Will ask Dev Team if we can fix that for you ;)
geposted Mon 08 Oct 07 @ 8:01 pm
hi eric
the only way i know is you must go into clipbank to load and press loop for continuous play after loading your clip, as i dont have a midi norway who i think designed it will be able to give a better qualified answer...
Tayla
Tayla
geposted Mon 08 Oct 07 @ 8:04 pm
bollocks, you did it again, this is getting weird... cue music from the "outer limits"...
Tayla
Tayla
geposted Mon 08 Oct 07 @ 8:07 pm
Thank you... it would be great if we maybe could have a checkbox under CONFIG that says something like:
Allow non-audio files to load direct.
geposted Mon 08 Oct 07 @ 8:19 pm
Could always add a 'dead air' audio track to the video clips.
geposted Mon 08 Oct 07 @ 9:04 pm
That would be a major hassle.... I believe any VOB should be loadable with or without audio. By the way, is there a way to make the regular player loop a track continuously?
geposted Tue 09 Oct 07 @ 1:49 am
Any verdict on this? Will the development team be able to add a checkbox somewhere to allow loading these ambient videos direct?
geposted Thu 11 Oct 07 @ 6:43 am
Eric dont know if this will help you or not, but you can create more than 1 clipbank, I for example have 7 that I use. Go to My Documents/Virtual dj/Plugins/Video effects and find the clipbank.dll and copy it to the desktop then rename it to clipbank2.dll and put it back into the video effects folder. I mean at least you can get 50 or so loaded and keep changing them as needed.
geposted Thu 11 Oct 07 @ 8:37 am
Yes, but the point is that I'm using ambients / billboards/ chromakey so frequently that I need them to be just as accessible as the music videos themselves. It really is much more cumbersome to have to search among hundreds of these files via numerous clipbanks, then to browse in a pre-organized directories.
Norway DJ.... can this be incorporated in a future revision?
geposted Fri 12 Oct 07 @ 7:19 am
I understand what you are sayin, maybe there is something that could be done who knows:)
geposted Fri 12 Oct 07 @ 8:29 am
