Hey guy... this is my second post on this issue… sorry… but I can get mi laptop running as good as my desktop, I am using a laptop del precision M6300 duo core 2 with 2 gigs of ram and Nvidia Quadro FX 1600m video card.
Everything works great but when I use the video hardware accelerator the video start to freeze like for 5 to 10 seconds, and sometimes a green line appears, I have already installed the latest drivers but it is still the same… what can I do to fix this?
geposted Tue 09 Oct 07 @ 9:10 pm
Sorry, maybe I'm confused. If everything works fine, why do you use the hardware accelerator? Perhaps I just don't understand what you mean. Are you referring to the "hardware acceleration" checkbox in VDJ?
geposted Tue 09 Oct 07 @ 9:22 pm
Yes doc, he meant the hardware acceleration in the video setting, i think so..
Hmm , if a green line usually appeared like that, usually there something wrong with ur card, or it is not good enuff.. Btw what os are u using?
geposted Tue 09 Oct 07 @ 9:26 pm
Also, aren't there some "horror stories" floating around about nVIDIA cards? How much RAM does it have?
@Spinna - thanks :)
@Spinna - thanks :)
geposted Tue 09 Oct 07 @ 9:33 pm
my OS is XP here is a link and info on the video car guys, i really apreciate the help..
http://www.dell.com/content/products/productdetails.aspx/precn_m6300?c=us&l=en&s=bsd&cs=04
geposted Tue 09 Oct 07 @ 11:57 pm
Its most likely due to the TurboCache thing Nvida has on some card... mess up gaming too.
Try the RiverTuner drivers to turn it off :
http://downloads.guru3d.com/download.php?det=163
http://howtotroubleshoot.blogspot.com/2007/05/how-to-disable-turbocache.html
geposted Wed 10 Oct 07 @ 12:03 am
I have also had mad problems with the Nvidia cards. I ended up returning the computer as I couldn't get it sorted.
geposted Wed 10 Oct 07 @ 5:18 am
Ok Guys, i did the RIVATUNER thing and it runs better, but still freezes some times like for 5 seconds... any other sugestions bessides sending it back?
thanks for all the Help!!!
geposted Wed 10 Oct 07 @ 9:48 pm
