Hi. I was told that when i bought VDJ i would have some software that would allow me to rip vinyl and DVD's? Am i right? Where do i find this software? Thanks, Ben
geposted Tue 09 Oct 07 @ 10:44 pm
hi ben, could u register ur serial at ur modifiuser page n yah vdj do came with that if u buy from this site.
geposted Tue 09 Oct 07 @ 10:47 pm
Can i not download it? Thanks, Ben
geposted Tue 09 Oct 07 @ 11:32 pm
What download the RipVinyl and RipDVD ? They are benefits of purchasing the software... don't think they are part of the trial.
geposted Tue 09 Oct 07 @ 11:34 pm
Ive bought the hardware and the software so shouldnt i get it like you say?
geposted Tue 09 Oct 07 @ 11:46 pm
u bought NVV?? As if i not wrong to have read a post from other threads from u that u gonna buy that or am i'm dreaming..hee? If so, do register for ur free plug in, skin n upgrades etc.. The thingy that u want should be in ur folder when u installed it:)
geposted Tue 09 Oct 07 @ 11:49 pm
Where do i register? All these little applications (RipDVD/VINYL etc) are not in a folder. Any ideas? Thanks, Ben
geposted Wed 10 Oct 07 @ 12:17 am
You register here:
https://virtualdj.com/fusers/modifuser.html
Enter serial there will show that you are a full user :)
geposted Wed 10 Oct 07 @ 12:37 am
Thanks for that. Im now a full user but still dont have the RIP VINYL software. Any ideas? Thanks, Ben
geposted Wed 10 Oct 07 @ 1:40 am
go to downloads and try downloading software and re-install.
geposted Wed 10 Oct 07 @ 2:09 am
So im rite abt u buying NVV.. hee,, i not dreamin after all.:P.. Welcome to the pro side..
N Btw have u found what u looking for? Reinstall already?
geposted Wed 10 Oct 07 @ 8:48 am
I have downloaded it again and it installs Vitrual Vinyl and RIP DVD. I need Rip Vinyl. Im really not sure where i can get hold of this? Thanks, Ben
geposted Wed 10 Oct 07 @ 11:08 am
look in C:/programfiles/virtualvinyl
or C:/programfiles/cue
for RIPVINYL.exe
aslo try downloading the latest update for cue if this doesnt work
for RIPVINYL.exe
geposted Wed 10 Oct 07 @ 1:13 pm
I have a mac so this wont apply. I have looked in my applications folder and there is only virtual vinyl. No Cue, no Rip DVD/VINYL. I only have version 4.3. Would this make any difference? Will 5 have rip vinyl in it? Thanks, Ben
geposted Wed 10 Oct 07 @ 2:47 pm
I called Numark UK and they havent even heard Rip Vinyl/DVD. This is wierd? Is this website actually part of Numark or is it just selling and exchanging information about Numark Virtual Vinyl? Im beginning to this that this website made this software and you can only get it from this website. But then how come you can get support on here and downloads and register etc????
Thanks, Ben
Thanks, Ben
geposted Wed 10 Oct 07 @ 3:07 pm
Since you mention you are using the MAC verison. There may not be a MAC version of the Rip Vinyl
geposted Wed 10 Oct 07 @ 3:28 pm
no there is no mac version of rip vinyl i missed the old mac slip in there
for ripping vinyl on mac check out
audacity
http://audacity.sourceforge.net/download/mac
in future i would use the mac forum thats where the mac guys hang out :)
https://virtualdj.com/forums/61/MAC_Version_Technical_Support.html
audacity
geposted Wed 10 Oct 07 @ 4:03 pm
