can anybody tell me about rev4..is it some few bugs fix..cuz i have rev2 and its running great, do i need to install rev4? you guys recommend it? or just chill with rev2? thanks
geposted Wed 10 Oct 07 @ 1:28 am
all updates are better than the previous version - rev4 fix all known BUGS -
geposted Wed 10 Oct 07 @ 2:50 am
yes..download it.
its rock solid...
its rock solid...
geposted Wed 10 Oct 07 @ 3:08 am
aight then thanks fellas
geposted Wed 10 Oct 07 @ 5:42 am
From a non-VIP user, I must agree. The database works well now! There is a small issue with characters from another language in the database, but that is already being worked on.
geposted Wed 10 Oct 07 @ 6:43 am
From a VIP member, I can also agree, the software is very stable on my (quite old) laptop, we are very tough on VDJ when we test it.
geposted Wed 10 Oct 07 @ 8:39 pm
A second to Brendans point. No database issues, nothing for me. Just download. I've been running it for a month w/nothing but good stuff. The little probs that people have talked about has------ been fixed.
geposted Thu 11 Oct 07 @ 2:47 am
virtual dj 5.0Rev4 can control the new Denon DN-HC2500 . It would be better to use the denon than the Dac 3 because denon has its own interface. It has two sets of RCA jack outputs to hook it up to your mixer. The dac 3, you need to buy a mixer like the CM 200usb. You need to to use 3 usb ports on your computer or laptop and maybe a forth if you are going to use a external hard drive. The denon only uses one and maybe a second for the external hard drive.
geposted Thu 11 Oct 07 @ 4:38 am
