Why is it with some songs that when I try to tap out the BPM that nothing happens. I start to tap and the counter just stays at zero. If I double the tap it starts to count though.
I have 99 prolems coming in at 163.2 and tapping out the song changes nothing at all. The actual BPM is 93 and a 4 beat loop verifies this.
geposted Sun 31 Oct 04 @ 1:07 pm
yep rick you got 99 problems :)
geposted Sun 31 Oct 04 @ 3:29 pm
I had this with very slow songs, about 60 bpm,
like its out of range and vdj ignore the taps.
geposted Sun 31 Oct 04 @ 6:18 pm
Use the anchors; that's more precise and that's also easy to assign.
geposted Sun 31 Oct 04 @ 6:26 pm
stop playing R&B songs. start playing club/techno ;)
geposted Mon 01 Nov 04 @ 12:05 pm
as far as I remember, Jay-Z's "99 problems" was found correctly with the new BPM algorithm in VDJ....
did you try analyse the file for auto bpm? there are 2 DIFFERENT modes for analysing... try "ALL MUSIC" first, then "HIPHOP/TECHNO"....
I seem to remember that VDJ got that song right.... hope so. If not, enter 100 bpm manually, and then tap... should work
geposted Mon 01 Nov 04 @ 1:39 pm
