Nuo4....is it 12" or 19" mixer?
Sorry I'm only familiar with the metric system. I'm buying a roadcase and it works out hell of lot cheaper buying standard size cases.
geposted Wed 10 Oct 07 @ 11:39 pm
Its actually a little larger than a 12" mixer. I'm pretty sure it is 12 1/2 inches wide. I owned one and had to cut my case for it to fit. Its also quite a bit longer than the other standard 12" mixers. ie. Pioneer 500, 600, 800...ect.
geposted Wed 10 Oct 07 @ 11:44 pm
Most good table top mixers have "Rack Ears" available for an extra fee.
What these are, Peices of metal broke to a 90 deg angle that make a tabletop mixer rack mountable.
Check the accesories department at the retailer you're planning to buy your mixer at.
Or if you have a measureing tape, ball/peen hammer and a bench vise you can bend your own sheet metal rack ears. (this is what I would do)
geposted Thu 11 Oct 07 @ 12:08 am
Thnx guys. I've got the actual dimensions now 320 x 370mm for anyones reference.
geposted Thu 11 Oct 07 @ 1:18 am
