Having successfully populated and played tracks using the playlists, the tracks on those same playlists are now unplayable.
Clicking 'properties' on the tracks reveals the message "Impossible to open (filename) with the MP3 decoder"
How can this be corrected?
Thanks
Thanks
geposted Thu 11 Oct 07 @ 4:47 pm
What version of VirtualDJ are you running? I ask since in v5.0.4 when you right-click a file, "File Infos" is what appears and not properties, but it sounds like you are in the same window.
Did you move the tracks to another folder or delete them?
Are you using the demo version or the unstable cracked version?
geposted Thu 11 Oct 07 @ 10:39 pm
