Topic: Xponent Support?
I just bought an xponent controller and wished to try it with virtual DJ.
Can anybody send me the midi map for this hardware and Virtual DJ?
Thanks.
geposted Thu 11 Oct 07 @ 11:43 pm
its super easy to map
just go to remotes > options > midi
and map your desired actions
if you get stuck just consult the manual or ask here
https://virtualdj.com/contact/
in the latest pro edition there is native support
which will be improved in upcomming updates
aslo for pro users there is a mapped file
https://virtualdj.com/addons/tools.html
any news about the lights? arthey working now?
Happy mixing whatever your software is called
Tanzi
The software is called Tork.
Very similar to Traktor... I had flashbacks to the old days.
Haven't used traktor in a while.
The software is so so, the hardware is amazing.
I had originally bought a denon hc 4500 and returned it because it didn't work with vista.
I think that was a mistake by denon, and fortunately for me I found something I would've never used.
Although it's not rackmountable and it has a plastic case. It's some solid hardware, fast, excellet sound.
Best of all its a 3 in 1. Unbelievable.. Take this and a laptop to any club and you're set. Try taking a rackmount to a club... No space :S
Great job M Audio!
