Hello all,
I have just purchased virtual dj and am in the market for an external soundcard. I had read about one called the Gigaport AG (see link: http://floridamusicco.com/gigaportag.htm).
To the Virtual DJ development team, is this compatible with Virtual DJ? Also, is this good to hook up to a mixer? Pls advise.
Jean
Jean
geposted Fri 11 Jul 03 @ 7:21 pm
I also heard that Maya makes a USB based soundcard as well. Please let me know.
geposted Fri 11 Jul 03 @ 11:49 pm
Hi,
I too use a laptop. I use a split output from the onboard sound card. It sounds great!
geposted Sat 12 Jul 03 @ 12:20 am
may i suggest the M-Audio external USB sound cards. They are amazing products for the price. Definately professional quality.
geposted Sun 13 Jul 03 @ 5:20 am
Rick, is it also great when you plug it in a 2000+ W amp?
geposted Sun 13 Jul 03 @ 9:33 am
I use onboard on both pc's and I am using some pretty serious equipment with no problems.
geposted Sun 13 Jul 03 @ 10:09 am
oh man, my amp is only 1600 watts.
get's the job done tho.
geposted Sun 13 Jul 03 @ 3:15 pm
I'm with Creative Sound Blaster Extigy (external USB) and it's perfect. Go to www.creative.com for other external usb cards: there is one that is cheaper than the Extigy... It's MP3 + Check it out
Peroz
Peroz
geposted Mon 14 Jul 03 @ 9:56 am
Rick,
Have you used on live session on a disco with great amps???
It sound good too?
I use a laptop too.
It sound good too?
I use a laptop too.
geposted Mon 14 Jul 03 @ 4:18 pm
Well, my least amplified sound system includes a 1200 watt amp, and a set of 2 JBL 15" 2 ways, and an extra MTX 15 " 2 way speaker.
I use it 4-6 times every single week, in 4 different bars & pubs.
each night, it sounds great!
geposted Mon 14 Jul 03 @ 4:56 pm
I too use the Extigy and the sound is unbelievable. My speakers are all JBL and I use a QSC amp. I am crancking about 2200 Watts but I usually do weddings so the power is not usually needed but with using the ATOMIXMP3 and now this....the sound is absolutley perfect! I DJ every week several times a week from anything from Club Play to weddings to Frat Parties. Whatever you do, do not skimp on your sound card. You will pay later.
DJ Troyka
DJ Troyka
geposted Tue 15 Jul 03 @ 3:24 am
I've been DJing with the laptop for well over 2 years now. The only sound card I use now is the one that came built into the computer. Stock Sony Vaio. Many people seem to think you have to spend money on an external sound card. I find that it sounds incredible with the stock on-board sound card split to 2 channels on the mixer.
I had an external sound device for a while, I was using it at the one club where stereo sound could be used. I noticed no difference in the quality of the output, so eventually I stopped using it.
geposted Tue 15 Jul 03 @ 3:36 am
Rick, If you want to DJ in Mono that is true but I prefer stereo. Some people thinks that it does not make a difference but the sound is so much better in digital stereo.
DJ Troyka
DJ Troyka
geposted Tue 15 Jul 03 @ 5:24 am
Well, in many club, bar or pub type situations stereo is not only not needed, but also not practical due to speaker placement. I have found that the mono output sounds every bit as full and crisp as the stereo output. Spend your money on an expensive external sound card if you want to, but really it's not a requirement.
geposted Tue 15 Jul 03 @ 3:44 pm
Yes Rick.
Mono is enough in mant places. You're right.
geposted Tue 15 Jul 03 @ 4:12 pm
But Rick,
Your Stock Sony Vaio look better than my poor Conexant AC card. hehehe
geposted Tue 15 Jul 03 @ 4:13 pm
Its not about when you cranck it up, its about hiss at low level.
Btw, why do some clubs keep their sound at the werry edge of blowing their speekers and with so much distorsion that Barry White (mey he rest in peace) sounds like Donnald Duck?
geposted Tue 15 Jul 03 @ 4:39 pm
My laptop has Soundblaster Live 5.1, but no secondary soundcard. Are you saying that this is enough, and that I don't need to buy a secondary soundcard?
geposted Tue 15 Jul 03 @ 11:03 pm
It seems that some would say that you need a 2nd sound card. Personally, yours is already better than mine. I don't use a 2nd sound device any more. I DJ with my laptop 5 times every week. I think it sounds awesome!!
Best thing is for you to try it, and decide for yourself.
geposted Tue 15 Jul 03 @ 11:26 pm
Im using a MAYA EX extternal USB connected sound card with no problems at all. Works well once its configured correctly.
Mikey NL
Mikey NL
geposted Sat 09 Aug 03 @ 4:14 pm
