Forum: VirtualDJ Skins
Topic: DN-S3500 Suggestion How to change Time Elapsed
DJ ANGELMX or somebody else:
How can I change the time to REMAIN so that this is the time when you startup VDJ.
Everytime I start this skin, it starts with "time elapsed".
Changing it to Remain and close the program so that it will be saved, doesn't work.
geposted Sun 14 Oct 07 @ 11:50 am
You have the edit the InternalMixer.xml file which is in the DN-S3500_Suggestion_5.zip file. Make these changes.
Find this part of the file:
<textzone chan="1">
<size width="61" height="16"/>
<pos x="310" y="79"/>
<text font="Verdana" size="16" color="#FFFFFF" weight="bold" align="right" format="%Pspent"><icon><size width="46" height="6"/><pos x="316" y="74"/><down x="+0" y="+699"/></icon></text> ELAPSED
<text2 font="Verdana" size="16" color="#FFFFFF" weight="bold" align="right" format="%Pleft"><icon><size width="39" height="6"/><pos x="331" y="74"/><down x="+0" y="+1111"/></icon></text2> REMAIN
</textzone>
AND REPLACE IT WITH THIS:
<textzone chan="1">
<text font="Verdana" size="16" color="#FFFFFF" weight="bold" align="right" format="%Pleft"><icon><size width="39" height="6"/><pos x="331" y="74"/><down x="+0" y="+1111"/></icon></text> REMAIN
<text2 font="Verdana" size="16" color="#FFFFFF" weight="bold" align="right" format="%Pspent"><icon><size width="46" height="6"/><pos x="316" y="74"/><down x="+0" y="+699"/></icon></text2> ELAPSED
</textzone>
THEN FIND THIS PART OF THE FILE:
<textzone chan="2">
<pos x="948" y="79"/>
<text font="Verdana" size="16" color="#FFFFFF" weight="bold" align="right" format="%Pspent"><icon><size width="46" height="6"/><pos x="954" y="74"/><down x="+0" y="+699"/></icon></text> ELAPSED
<text2 font="Verdana" size="16" color="#FFFFFF" weight="bold" align="right" format="%Pleft"><icon><size width="39" height="6"/><pos x="969" y="74"/><down x="+0" y="+1111"/></icon></text2> REMAIN
</textzone>
<textzone chan="2">
<size width="45" height="16"/>
<pos x="898" y="79"/>
<text font="Verdana" size="16" color="#FFFFFF" weight="bold" align="right" format="%Pbpm"><icon><size width="21" height="6"/><pos x="921" y="74"/><down x="+0" y="+699"/></icon></text>
<text2 font="Verdana" size="16" color="#FFFFFF" weight="bold" align="right" format="%Ppitch"><icon><size width="30" height="6"/><pos x="913" y="74"/><down x="+0" y="+1111"/></icon></text2>
</textzone>
Let me know if you have trouble. I'll email you the modified file.
Alan
Alan,
You're my hereo !!!!!!!!!!!!
Thanks, it's great, it works.
Many thanks
Best regards,
Anthony
:D:D
Congratulations! I'm using the TCB Skin. Any chance to get this on this skin? Any help would be much appreciated. Thanks!
happyuser
