Apparantley you can play all certain types of files on version 2.1 m4a for example.. does anyone know where I can download this version??
a link maybe? anyone?
thanks :P
thanks :P
geposted Sun 14 Oct 07 @ 9:16 pm
you can play all types of non drm files on the latest version too
try the demo
try the demo
geposted Sun 14 Oct 07 @ 9:54 pm
All the way back to version 2.1? I still have version 3.4 (setup file) since a lot of audio effects I have do not work in 5.0.5 and that is the version where I fell in love with VirtualDJ. :-) I wonder how that looked like.
geposted Sun 14 Oct 07 @ 10:19 pm
i'm using the latest version (demo) and when I load the songs from my itunes library,, half them wont play, saying m4a error.. how do I change them? or make them play? thanks
geposted Sun 14 Oct 07 @ 10:59 pm
This should be in the "Technical Support" section. What error do you get when right-clicking the file and selecting "File infos"? "Immpossible to read file !!"?
geposted Tue 16 Oct 07 @ 12:03 am
are they from the itunes store because only itunes can play those files?
geposted Tue 16 Oct 07 @ 12:05 am
no, i didnt buy any from the itunes store... the ones that arent working.. i can right click on them..they seem fine .. they are all m4a files.. and the song title is all that is there.. no artist... (on the right section of VDJ) so when I drag it on.. it just says m4a error...
i tried retagging these mp3's or converting them to mp3's.. changing the idtags.. nothing is working..
geposted Tue 16 Oct 07 @ 1:34 am
You have two threads on the same topic going. I am closing this one and continue your discussions here -
https://virtualdj.com/forums/78699/General_Discussion/no_answer_yet___can_t_play_m4a_files_in_VDJ_-_pls_help.html
Thank you.
Thank you.
geposted Tue 16 Oct 07 @ 4:27 am
