Hi all,
I've downloaded the demo of VD5, and I'm going to purchase it. Here is my question.
I noticed the database is saved on my external harddrive ( which my music files are stored ) and not my Laptops harddrive where the VDJ is stored. Why is the database saved on my external. Surely this is not right ???
I'm confused.
Jimmy B
I'm confused.
Jimmy B
geposted Mon 15 Oct 07 @ 12:18 am
The place the datebase is stored was changed in v5..this was to work better with Vista. Also the database on your ext HD is so you can bring just your hard drive to another venue using v5 and hot swap your ext HD and all your cue points and such will be saved.
geposted Mon 15 Oct 07 @ 12:45 am
Thanks, TearEmUp,
I can See the sense in that, But does that mean VDJ will not run right if I do not have my external HD attach to my laptop and just run of the Music files I have on my Laptop HD. Forgive me if this is a daft question.
Also can I change where the database is stored if I want to.
Jimmy b
Jimmy b
geposted Mon 15 Oct 07 @ 12:52 am
No, your VDJ should run fine.....I swap my ext HDs back and forth all the time.
geposted Mon 15 Oct 07 @ 1:07 am
As TearEmUp said, VDJ will run fine - but as you mentioned - if you don't have your external connected the only Database info and tracks available will be the ones stored locally on your internal harddrive.
No, the database locations are key. If moved then VirtualDJ will not be able to find the information necessary and create fresh databases back in the proper locations.
geposted Mon 15 Oct 07 @ 1:41 am
Cheer's cstoll
You are the man :)
I will be purchasing VDJ 5 for certain now, when my new Bank card comes, Damned postal Strike. ( I live in England )
Jimmy b
geposted Mon 15 Oct 07 @ 1:47 am
