Forum: Old versions
Topic: what sound card should i buy
I have a hercules mp3 and i want to pre listen the next song and i know i need to buy a usb sound card for my laptop. Can anyone please tell me the best card to buy weather it be better to buy a 4.1 or 5.1. can it have front and center sub and rear audio. thanks
geposted Mon 15 Oct 07 @ 6:07 am
I use a gigaport ag it has 8 rca jacks that's 4 channels it's usb works great with laptop
will this work?
<img src="http://images.tigerdirect.com/SkuImages/gallery/large/TC3G-3012-a.JPG">
@Platinum beatz. i upload the pic from the link for betta referances.
I think "maybe" it could but i would advised not to purchase it as i went to the site n see bad review abt it..
REVIEW BY: Tenchi Reviewed Oct 05, 2007
Bought this to use my Razer Barracuda gaming headphones. I cannot use the stock card that support the headphones because I have a laptop. The quality is not good but for it's price it is not bad (if you keep your volume down you don't hear the hum). It is great if you want to experience 5.1 audio and you cannot afford anything better.
REVIEW BY: Johnst Reviewed Jul 24, 2007
Terrible audio, all outputs have a high frequency hum on them. Source a different product
Search the forum n look for wat other user are using for 5.1 cards n that werks:)
thanks for the review above what about this card?
Zalman External 5.1Ch USB Sound Card (ZM-RSSC)
or
Behringer UCA202 USB Interface
any 5.1 card can werk:) A good 5.1 n cheap is the soundblaster 5.1 usb etc but betta still take a look at the djio. It proven to be good for prelistening and audio is good too.
https://virtualdj.com/products/hardware.html
Cheers.
$99 bucks.. Numarks DJiO
does anyone know how to set up a zalman 5.1ch sound card?
i suggest the gigaport AG or HD or the DJIO. these are reasonably priced sound cards, the ones you all are listing i don't even think you should use those for djing. for good sound quality you cant go wrong with any of the ones i have listed. The DJIO is only a four channel and the Gigaport models are eight channels.
