Hello, Ive been using virtual dj for a while now, i first used it to learn what the hell was all this mixin music about....then i started to get the hang of it, at first i would mix just with the mouse, then i wanted to to do more so i bought an M-audio usb mixer, and it works great with virtual dj, so now that i know how to use the program well and i know how to use a mixer pretty well, i wanna upgrade to the real dj stuff, right now i have a laptop so im good with that, i would have to get the two turntables plus a mixer, and since i wanna keep using virtual and i dont wanna be spendin money on vinyls, im thinkin of buying the timecoded virtual dj vinyls and learn to mix with them....NOW.....what do i need to get to set this up fine? does the stanton final scratch work with virtual dj and the vdj timecoded vinyls, or does vdj have its own final scratch?? please i wanna hear suggestion i really dig the djing stuff and i wanna keep progressing....thanx!
geposted Mon 15 Oct 07 @ 11:01 pm
i would recomend you get a card like the maya 44 usb
for timecoded vinyl
vdj doesnt support final Stratch vinyls
but the Generation 2 stratch amp should work with vdj if you already have this
however if you dont go with the maya
you can buy vdj ones here
https://virtualdj.com/shop/
for timecoded vinyl
geposted Mon 15 Oct 07 @ 11:38 pm
