Is there any way to use more than 2 decks in VDJ?
Especialli appreciated when mixing acapella's on instrumental, keeping it running as a new version, and mixing into a third song...
Untill now, I haven't find this option.
If not available would be a nice to have.
Thx.
Thx.
geposted Mon 01 Nov 04 @ 8:48 pm
yes this is possible.
eneble multi users in the settings of vdj.
then you can open several vdj's at 1 time.
even beatmaching works. (read the helpfile)
geposted Mon 01 Nov 04 @ 9:23 pm
djjb, do you mean that you can have 2 instances of vdj open and all 4 decks would simultaneously be able to sync and beatlock?
geposted Mon 01 Nov 04 @ 9:41 pm
keyon: that's right. Look in the "Network sync" panel in the VDJ configuration ;)
geposted Mon 01 Nov 04 @ 11:00 pm
but wasn't there another adress you have to type in for 2 vdj at one pc?
geposted Tue 02 Nov 04 @ 2:19 am
127.0.0.1 is a loopback interface, meaning that using this address will connect to your computer (the signal "loops back" to the computer that sent it).
geposted Tue 02 Nov 04 @ 2:30 am
how do you control what deck is the output ?
geposted Tue 02 Nov 04 @ 2:50 am
brilliant. thanks djjb & marcouteau, i had no idea it was possible to sync them all. like yvesmk, i thought it would've been nice to have this feature. little did i know it was already there!
geposted Tue 02 Nov 04 @ 8:25 am
I found this in the manual:
"Network
If you want to use more than two instances, or if you want mixer with several at the same
time, you can synchronize several VirtualDJ between them thanks to OSC protocol."
I have VDJ installed on the laptop I use for Djing, and installed on my desktop PC here at home.
I've now networked them, typed in the IP address, but now what? How do cross over from one computer to the other?
"Network
geposted Tue 25 Apr 06 @ 1:16 am
If you are recording a session with 2 instances of Virtual DJ will this record the sound from the other session as well?
geposted Tue 25 Apr 06 @ 8:36 am
@DjGazUK
You have to enable beatlock() on the decks to synchronyse them
geposted Tue 25 Apr 06 @ 2:25 pm
Does anyone here knows how to sync 3 or more instances?
I have tried to do this but no luck...
Thanks
Thanks
geposted Wed 26 Apr 06 @ 2:53 pm
