Forum: Old versions
Topic: 2.05 crashed and PLAY/PAUSE and STOP buttons broken
Just burn the installation file to a cd rom.
(Do you have a cd writer ?)
(Keep your serial number along, or maybe to a text file in the cd.)
Simple ?
You said :
"The controls in VDJ that stopped working are the STOP, PLAY/PAUSE buttons. When I click on them the song will reverse to the begining."
Check if you use the reverse plugin.
If you have a song at the beggining in stop mode and reverse
effect is acivated, then the song will not start if you press play...
geposted Tue 02 Nov 04 @ 2:57 am
isn't this something for hercules?
i tried putting the install file on a cd, but i was unable to re-install.
Program was stopped and a message to contact VDJ support displayed.
They had to issue me a new install to download.
Also, I did not activate the effects, or any other part of the program. In fact I have never even tried using them.
I unplugged the hercules dj console and the program had the same problem.
Sir, your e-service messages are confidential. Please do not post them on the forum. For this reason, your message will not be viewable by everyone.
what is e-service ?
WirelessDJ: e-service happens to be the technical support, the place to get protection errors fixed, or the place to get answers for any question that can't be answered on the forum ;)
macourteau
oh, that is nice. I thought it was a 3rd party company or something.
