Hello,
I just wanted to ask if the Mac verison of VDJ is better (or as good as) the PC version?
I'm going to buy a Mac soon, if you guys don't make me buy another PC :p
So, is the Mac version of VDJ stable..?
Is it anything that don't work with Mac?
I have Herc. MK2 and TCV's... will this work with the Mac version?
I don't like Vista, so if I buy a PC, I'll make someone build a PC for me with XP :)
geposted Wed 17 Oct 07 @ 5:32 pm
the V5 update for mac will be much more stable ,
it will support your mk2 yes
which one did you have in mind?
geposted Wed 17 Oct 07 @ 7:58 pm
I'm going to buy an iMac not sure if I will choose a 20" or 24" .. .. we'll see... but thanks.
do you know when this update will be released..?
geposted Wed 31 Oct 07 @ 4:58 pm
My Macbook Pro runs Windows better than any other PC I have ever used. If you buy a new iMac it will have Bootcamp installed. You can then install Windows on a separate partition and use it strictly for VDJ. Keep your OS X 10.5 side for everything else.
geposted Wed 31 Oct 07 @ 5:13 pm
thats smart... but won't it be better to use the Mac version of VDJ..?
and I've heard of a program or something that can run Windows apps on mac.. is that true..?
geposted Wed 31 Oct 07 @ 10:47 pm
is Leopard in the stores now ?? i thought it was due soon .......read raves about it ........
geposted Thu 01 Nov 07 @ 1:40 am
its out now :)
geposted Thu 01 Nov 07 @ 9:10 am
10.5 osx lets you install xp or vista onto your mac and at boot you can choose mac osx or windows
this is called bootcamp
however V5 mac comming out very soon is very stable so you may be happy to just use that :)
geposted Thu 01 Nov 07 @ 9:12 am
Sounds good, can't wait.. :)
geposted Sun 04 Nov 07 @ 4:29 pm
Yes, definitely.
Soon you'll have the most stable and best full featured digital dj/turntablist/Visual Turntablist software VirtualDJ 5.0/Virtual Vinyl 5.0 combined with the world's most advanced, stable and best full featured Operating System, Mac OS X 10.5 Leopard.
VDJ/VV 5 with Mac 10.5, the best of both worlds without a doubt. ;)
- VT ConQuest
(Visual Turntablist)
geposted Mon 05 Nov 07 @ 4:30 am
Sounds really good...
I've been waiting for something that is really stable...
And thats true, best of both worlds.. :)
geposted Thu 08 Nov 07 @ 4:24 pm
