I was looking for a Multi-instance skin, but only see 1 by DJCell and it says it\\\\\\\'s for the home user version. I\\\\\\\'nm a 5.0 professional user. Is there a multi-instance skin or can someone make one?
Is there a tutorial for how to use a mullti instance skin so that I can control and mix 4 decks at once? From the little info. I was able to find, it sounds like I need a second controller that is different from my current one, and a second soundcard. I detailed, step by step explaination would be appreciated.
geposted Wed 17 Oct 07 @ 7:14 pm
