Forum: VirtualDJ Skins
Topic: V-Mix Multi-instance skin question
I just downloaded the skin and tried it out. I see the two decks and can load and play, but I get 2 seperate video windows. One for the first deck and a second for the other deck. Shouldn't the 4 decks all send their video to only one main video out screen? In the configuration window on both decks I set the network tab to Local Syn (multi Instance), but it had no effect.
How do you get all 4 decks to show on only one video output and how do you select which deck will show up on the main video out? If I am mixing two video's on the first instancve, and then I want to mix in a video from the A deck of the second instance, how do I do that. Right now as I said there are two Main video out windows.
geposted Wed 17 Oct 07 @ 8:39 pm
what you need to do is enable multiinstance mode
which opens two vdjs in one window
set local sync
and you need two video cards to use 4 decks of video ,
Cstoll told me currently you can't use 4 decks to mix the video onto the secondary output screen. He said I'd need 2 seperate laptop systems and an external video mixer to select and mix the 4 channels. Hopefully you have a better suggestion or solution?
when i have seen it used a micro tower was used and two video cards
Just to clarify my comments - I did include the 2 video cards for output statement. However, I personally had not seen it done. Evidently, Skyfxl has seen it with 2 video cards and a multi-instance skin. And I am sure the setup included an external video mixer to mix the 2 output signals.
yes they used a external video mixer
was a beast of a machine that computer
