Forum: Old versions
Topic: DirectX sound driver error
I pretty sure this is a brand new real bug to be addressed by VDJ.
I updated my media player to version 10 and since then I get a message: DirectX sound driver error
each time I start VDJ 2.05 with or without my DJ Console.
I suspect that Media Player has installed a brand new DirectX driver that has some incompatibilti with VDJ. The good news is that I can still use VDJ.
But I think you should look into this ASAP since it can affect all your XP client base.
geposted Tue 02 Nov 04 @ 3:47 am
i don't have this message....i did the same with media player.
10 is great.
nothing wrong here.
That may mean that the sound device that you most recently used is not plugged in the next time you started VDJ.
I get this message whenever I forget to plug the xp-10 in first.
Plug in the sound device first, then launch VDJ.
Correct. I no longer have this message.
Thanks
i got the message when i used the extigy as 4.1
