I want something that will run videos with no problems. I will be using time coded vinyl and am a turntablist so i want to know what will work best. If there are any other turntablist with suggestions i would appreciate it. I found this asus laptop but not sure if it can handle what i want.
http://www.newegg.com/Product/Product.aspx?Item=N82E16834220195
Model
Brand ASUS
Series F3 Series
Model F3KA-X1
Part# 90NPNA1831884CQL600Y
General
Operating System Windows Vista Home Premium
CPU Type AMD Turion 64 X2 TL-56 (1.8GHz)
Screen 15.4" WXGA
Memory Size 1GB DDR2
Hard Disk 120GB
Optical Drive DVD Super Multi
Graphics Card ATI Mobility Radeon HD 2600
Video Memory 512MB
Communication Modem, Gigabit LAN and WLAN
Card slot 1 x Express Card
Dimensions 14.2" x 10.5" x 1.1-1.6"
Weight 6 lbs.
CPU
CPU Speed TL-56(1.80GHz)
CPU L2 Cache 1MB
Chipset
Chipset AMD M690G
Display
Screen Size 15.4"
Wide Screen Support Yes
Display Type Wide XGA
Resolution 1280 x 800
Operating Systems
Graphics
GPU/VPU ATI Mobility Radeon HD 2600
Video Memory Dedicated 512MB
Graphic Type Dedicated Card
Hard Drive
HD Capacity 120GB
HD RPM 5400rpm
HD Interface SATA
Memory
Memory Speed DDR2 667
Memory Size 1GB
Max Memory Supported 4GB
Memory Spec 1GB x 1
Optical Drive
Optical Drive Type DVD Super Multi
Optical Drive Interface Integrated
Communications
Modem 56K
LAN 10/100/1000Mbps
WLAN 802.11b/g Wireless LAN
Bluetooth Yes
Ports
Card Slot 1 x Express Card
USB 4
IEEE 1394 1
Video Port 1 x S-Video TV-out, 1 x DVI
Audio Ports 1 x Microphone jack; 1 x Headphone jack
Audio
Audio Integrated Sound card
Speaker Internal Speakers
Input Device
Touchpad Yes
Keyboard Standard
Supplemental Drive
Model
Brand ASUS
Series F3 Series
Model F3KA-X1
General
Screen 15.4" WXGA
Hard Disk 120GB
Video Memory 512MB
Weight 6 lbs.
CPU
CPU L2 Cache 1MB
Chipset
Chipset AMD M690G
Display
Screen Size 15.4"
Operating Systems
Graphics
Hard Drive
HD Capacity 120GB
HD RPM 5400rpm
HD Interface SATA
Memory
Memory Size 1GB
Memory Spec 1GB x 1
Optical Drive
Communications
Modem 56K
LAN 10/100/1000Mbps
Bluetooth Yes
Ports
USB 4
IEEE 1394 1
Audio
Input Device
Touchpad Yes
Keyboard Standard
Supplemental Drive
geposted Fri 19 Oct 07 @ 8:01 pm
From personal experience I’ve been through 3 laptops all with good specs & the outcome was audio no problem video as long as you don’t use a skin that has the 3 little monitors for monitoring the video you are fine .Now I’ve switched to pc & running everything with out any glitches, hope this helps………………
geposted Fri 19 Oct 07 @ 8:10 pm
uhhh i'm not quite sure .... if it was XP and you had a gig of system ram , and 512 for the video card i wouldn't hesitate to say get it ..... i do not use Vista on my gig rig or backup ... only know vista a little since i bought a lappy for my daughter ...
i consider 1 gig system ram to be the minimum for any Vista system ..... so i'm thinking even though the video card seems strong , the system ram should be more ......
it'll support up to 4 gig ask about that ..... when you get it home , if that happens when it comes outta the box it is NOT going to be gig ready .......
use the info in the " stickies" at the top of the page to setup , especially the setup guide .... or ask for help .... it is very probable that you will need to make changes in order for the operating system to agree to cooperate with your soundcard and the software .......
geposted Fri 19 Oct 07 @ 8:20 pm
