Two Bugs to report,
1, When shift selecting multiple files in the browser, you must select the top one first then press shift and select the bottom one, this should also work in reverse, selecting the bottom one first, but will not.
2, Automix Type is not remembered always seems to start on,,,,, Double checks to find user error, Automix type is very smartly saved with each playlist, Well done devs! Just did note there is no way to Üpdate an existing playlist, unless you manage to remember the exact playlist title.
geposted Sat 20 Oct 07 @ 10:30 am
