Hello All,
I was djing the other night and all was going well until suddenly a yellow vertical line appeared on the left hand side of my monitor. Every now again it flashed on and off. VirtualDJ was not affected but i am concerned whether or not this will grow into a bigger problem. Does anyone know if this is a graphics card issue or a monitor issue, or a dying PC???
I have a wedding to do tonight and will be taking a graphics card with me just in case but i would just like to know whether anyone else has experienced this problem. The graphics card in my shuttle cube pc is a 64mb AGP (not great but i don't use video...yet!)
Thanks
Craig
Thanks
Craig
geposted Sun 21 Oct 07 @ 11:40 am
Do you use a TFT or a tubes monitor? Have you tested your shuttle pc on another monitor and when yes, have you the same problem?
I think it is a monitor issue but maybe it is a grafic card error. When your grafic card blow out, you most have a glint.
Test your shuttle on another monitor and look if you have the same effekt.
And for your wedding i think it is better if you have a alternative (a laptop or somethink like this).
geposted Sun 21 Oct 07 @ 12:20 pm
