Hey. I've had VirtualDJ cracked for quite some time now. When I opened it up a few days later, The volume of the left vinyl is quieter than the right. How do i fix this so their both equal? As you can see on the picture below everything is in the middle, The crossfader is in the middle and the green line at the left is still lower than the right one, Again how do i fix this? Thanks alot.
Picture=http://img141.imageshack.us/img141/6423/virtualau1.jpg
geposted Mon 22 Oct 07 @ 12:40 pm
Honesty is one thing and expecting free support from VirtualDJ forums for cracked versions is another. Note that it didn't say "Cracked VirtualDJ forums" there. To answer your question, there may be more protections than just the time limit which makes it difficult to tell a poor crack and a real problem apart.
geposted Mon 22 Oct 07 @ 6:39 pm
if you like this software please support its development by purchasing it ,
if you dont need all the features of pro at the moment why not try home edition
https://virtualdj.com/products/homeedition.html
or check out one of the controler packages such as mk2 and the mp3 console
https://virtualdj.com/products/hardware.html
to see the differences between the products
comparison
comparison
geposted Mon 22 Oct 07 @ 6:51 pm
Simon says it all, go legal > Gain Respect ;)
geposted Mon 22 Oct 07 @ 9:47 pm
lmao @ the new icon for him.......
go legal and the problem will be solved, 10 to 1 odds say "it's because your version is hacked"
the only way to fix that issue is get a real paid for copy of the software buy purchasing it,
hope to see you as a legitament registered licsensed user soon :)
geposted Tue 23 Oct 07 @ 12:39 am
