Forum: VirtualDJ Skins
Topic: Loading a skin????
Hello. Would like to ask, how to load a skin in to VDJ? Have some skins wich i could not load in VDJ? All of the skin's i have is xml. files and loaded in skin's map. But everytime when i open a software there is nothing in skin section?
Hope someone would help?
Thanks in advance.
geposted Mon 22 Oct 07 @ 3:13 pm
you need to be a pro user to get more skins hope to see you with us soon :)
You don't have to unpack the zip file.
Just put it in C:\\DOCUMENTS AND SETTING\\SESSION\\VirtualDJ\\Skins.
It will then appear in the vdj's skin list.
