Hey. I've had VirtualDJ for quite some time now. When I opened it up a few days later, The volume of the left vinyl is quieter than the right. How do i fix this so their both equal? As you can see on the picture below everything is in the middle, The crossfader is in the middle and the green line at the left is still lower than the right one, Again how do i fix this? Thanks alot.
Picture=http://img141.imageshack.us/img141/6423/virtualau1.jpg
P.S: Sorry for double post, I can't login to my other account FSR.
geposted Mon 22 Oct 07 @ 3:24 pm
Have you tried to mess with the GAIN?
geposted Mon 22 Oct 07 @ 4:23 pm
Yes i have. On the picture, At the right of the left vinyl, The green bar is lower than the right one, And I i've messed with loads of things and it hasn't worked. But if people still have ideas, please post them. Thanks.
geposted Mon 22 Oct 07 @ 4:27 pm
Well at least in this post you didn't state that you're using a cracked version like in your other post. Go into Timecode configuration and play with the settings in there. I don't have the program in front of me but I beileve there is a gain slider there, in the advanced view. Then please buy the program. Cracked versions aren't stable and you'll get much more help here if you're using the Pro Version.
geposted Mon 22 Oct 07 @ 4:39 pm
I didn't write that.. It got added in there because i wrote a serial from my VirtualDJ and put it into my profile and it said invalid.. But it works with my virtualDJ? And i swear i bought it, I'm no good at telling if i bought it illegally though.
geposted Mon 22 Oct 07 @ 5:09 pm
Where's the Timecode Configuration? I can't seem to find it.
geposted Mon 22 Oct 07 @ 5:10 pm
Ah i fixed it now. The Crossfader was set to User, Not smooth..
Thanks for the help anyway guys.
picture=http://img90.imageshack.us/img90/3627/corssfaderiz0.png
geposted Mon 22 Oct 07 @ 5:21 pm
