Two questions: When re-naming the history, 1. where does it go and 2. how do you bring it back into Virtual DJ? Thanks for the help!!
geposted Tue 23 Oct 07 @ 10:17 pm
In ver 5 History is in my documents vdj folder.
If you just rename it I don't believe it changes location. Still in same folder
geposted Wed 24 Oct 07 @ 8:33 pm
I renamed one history and it change the dinamics of the file. I forgot where I end finding it.
geposted Wed 24 Oct 07 @ 8:58 pm
I renamed one of the dates in the history and it's not there any more...I would like it back in the history folder...I don't know how to get it back??
geposted Thu 25 Oct 07 @ 4:42 am
Try a search in windows for the filename (the one you renamed). Once you find it
you should be able to cut or copy and paste it where you want it.
geposted Thu 25 Oct 07 @ 7:12 pm
I tried tried that once before but once you rename it changes the file type and VDJ did not recognize it any longer... At least it was the case in v5.0.2... sorry not home to try again.
geposted Thu 25 Oct 07 @ 7:16 pm
Does anyone know the correct way to rename the history dates so they stay in the history??? I did find the file but virtual didn't recognize the new file name... thanks
geposted Fri 26 Oct 07 @ 2:51 am
It will stay there just rename it but dont erase the .m3u at the end, just did it here and it works. Click on the + next to History, select the date, right click and select rename and look carefully at it and you will see the .m3u at the end, as long as that is there it will stay there.
geposted Fri 26 Oct 07 @ 4:29 am
I tried it and it worked...still don't know how to get the old file back in VDJ....thanks alot...this will help!!! Bob
geposted Fri 26 Oct 07 @ 6:24 pm
What file type did it change to? I don't know if you can play it in window media or any other file burning and copy the playlist to m3u. Just thinking!!!
geposted Fri 26 Oct 07 @ 6:49 pm
Just do another rename, and add back the extension .m3u
I screwed up an mp3 by omitting the extension, tried this method, and it worked ;)
geposted Fri 26 Oct 07 @ 8:01 pm
Do a search in XP for the file name that you named it and simply add the .m3u to the end of it and add it to your playlist folder, yes it will put it there and not in the history.
geposted Fri 26 Oct 07 @ 9:23 pm
I did do a search and found it, I add the .m3u to the end of it and it put the file back in the history folder....THANKS ALOT for the help!!!
geposted Sun 28 Oct 07 @ 8:45 am
BEAUTIFUL glad we could help:)
geposted Sun 28 Oct 07 @ 10:23 am
Glad you got it worked out :):):)
geposted Sun 28 Oct 07 @ 5:41 pm
