I have a laptop hooked to a maya ex soundcard and have output 1 and 2 going to deck 1 and output 5and 6 going to deck two of a VMX 1000 Behringer mixer. I want to be able to play each deck of VDJ in the respective decks of the mixer. Not working as of right now. Also what is best way to use headphones in this confiig? Going to wedding for first time and trying to find best solution. Please help!
geposted Thu 04 Nov 04 @ 4:15 am
i'm not sure if i understand your issue 100%, but i also have a Maya EX (5.1). it should work without any problems in wmd mode. it doesn't support all channels in asio-mode. If you want to use the asio-drivers, i would really recommend an Echo-Indigo DJ (pcmcia.. no usb) signal to noise ratio 111db, 4 channels, fully asio 2.0 compliant.. and rocks @ss in combination with VDJ 2.5
i still have my Maya EX but i don't use it anymore.
geposted Thu 04 Nov 04 @ 2:00 pm
What is wmd mode?
geposted Thu 04 Nov 04 @ 5:00 pm
WDM = windows driver model
It replaces (contain) the old "direct x" drivers
geposted Thu 04 Nov 04 @ 5:14 pm
I am having no luck getting the maya ex to allow me to come out of 4 of its outputs and go into two different channels of the external mixer. I am going out of outputs 1 and 2 and 5,6 of the card. Any clue. I use Windows XP Pro, do I need to do something to get WMD?
geposted Thu 04 Nov 04 @ 5:57 pm
what are your current configuration settings in 'advanced setup'
if you tell me exactly what it says, i can help you. I'm sure you missed some little setting.
geposted Fri 05 Nov 04 @ 10:55 am
DONT use advanced config, this is wrong.
Just use the 4.1 option with external mixer, like i said here:
http://www.virtualdj.com/forum/display.html?topic=7938
Set the volumes (master and wave/line to max)
The sound must be better than your on board.
Maya is a good card
Let me know
PS. Maya Ex and Maya44usb are different cards.
Maya Ex is a 4.1 card
Maya44usb needs asio for 4in 4out
Maya is a good card
Let me know
geposted Fri 05 Nov 04 @ 3:06 pm
Maya EX is a 5.1 card (not 4.1) it has 6 channels of output and it DOES work when you use advanced audio-setup.
i tried it myself and i want to help others. tell me why he should not use advanced audio setup?
geposted Mon 08 Nov 04 @ 10:32 am
If i remember well you bought the asio drivers from
propagamma, -if yes- the asio outs (from this driver) is what you see in advanced setup.
In fact what you see in advanced setup is :
1. all available asio outs
2. all available wdm outs
Maya Ex is plug and play, it uses the microsoft "generic"
usb driver. This driver support only 2in/2out and this is the
same with most usb devices.
It is the same for Hercules dj console, and Maya44usb.
ONLY stereo ins/outs with wdm.
Asio is another story.
geposted Mon 08 Nov 04 @ 3:05 pm
