FINALLY JUST GOT PRO YEYYYY HOW DO I USE OR SETUP MAPPER I NEED A FULL DETAIL HELP LIST PLEASE
geposted Wed 24 Oct 07 @ 5:39 pm
dowloand and run the file it will automatcialy be installed
then go to External Control on the FX tab
and enable the mapper , then you can asign functions to the console :)
geposted Wed 24 Oct 07 @ 5:58 pm
that i guess is my question how do i assign them
geposted Thu 25 Oct 07 @ 6:41 am
there should be a readme file in the package if not
basicaly you will see on this tab a image of the console and the buttons on it
click one of the buttons then from a drop down list of possible actions you can choose what this button will do
ie play , pause stop ect
for items which have more than one outcome for example pitch blend you will be required to set a value in the box next to the list
- 1 decrease , 1+ increase
i will get you some screenshot guides too ,
geposted Thu 25 Oct 07 @ 9:57 am
thanks got it doent really get the assign thing umm.. can i create my own like a loop shift or effect slider how does that work
geposted Thu 25 Oct 07 @ 11:41 pm
