Hi can someone help me please
I'm using DJ console 3.4 with the DJC Mk2 .
In config -> keyboard shortcuts -> add -> effects -> effect_slider
My question
Can I adjust the other sliders as wel ? How do I do this ?
Because I only can adjust the value of the first slider ...
Thx VDJ's,
Greetz
My question
Thx VDJ's,
Greetz
geposted Wed 24 Oct 07 @ 8:38 pm
The DJC is spacifically mapped out for the MK2 controls.. They cannot be modified with that version of software. If you had a home edition ( just as basic but a little more freedom ) or a V5. You could map what you need. But the DJC is a free software to get you accustomed to VDJ therefore only controls the MK2 as it was written.
Look to upgrade... you will not be dissapointed. And your DJ ideas will start flowing as soon as you start using it.
geposted Wed 24 Oct 07 @ 8:48 pm
I agree. Get the upgrade...I did, and I've never looked back. It's soooo much more than what you're using now, it'll make your head spin when you get your hands on it ;)
geposted Thu 25 Oct 07 @ 7:57 pm
