Hey,
I discovered this since v5.04 ...
when I load a playlist and play off it, everything is fine and smooth, BUT as soon as I start browsing and folders, the playlist window get cleared and is empty. This has not occured before. Is this a bug or an option I'm missing?
geposted Wed 24 Oct 07 @ 10:52 pm
Go check the settings for Autoload playlists. Config -> Options tab -> left column bottom - set to disabled . Does the problem still happen?
geposted Wed 24 Oct 07 @ 11:31 pm
I gave it a quick try, that seems to be it, WORKS !!!
... was set to intelligent
THANK YOU !!!
THANK YOU !!!
geposted Wed 24 Oct 07 @ 11:38 pm
