I wanted to know if I can use the xsessionpro with Virtual DJ 3.0. If I can, how can I? Currently when I click to activate the midi device inside the settings, the circle that appears to the right is red...I guess indicating that Virtual DJ does not detect a midi device. Any help?
Thanks
Thanks
geposted Fri 26 Oct 07 @ 7:00 am
please update to the latest demo
https://virtualdj.com/download.html
you will find it has many improvments
unoffical versions will never work correctly as they have been damaged
i hope to see you as a pro user soon :)
geposted Fri 26 Oct 07 @ 10:08 am
