Hello All!
I have a simple question before i decide to buy VDJ. Can i use a microphone using VDJ & my BCD2000? as i want to talk whilst im broadcasting live on my internet radio shows?? Any help appreciated.
Respek
Flapjack
Respek
Flapjack
geposted Sat 27 Oct 07 @ 5:44 pm
unfortunately virtual dj currently cannot process the bcd2000 mic as it works under asio only
support may be added in the future
the bcd has many hardware problems which make it unstable when mixing live i would suggest sterring clear of this controller
geposted Sat 27 Oct 07 @ 5:47 pm
now now sky, pls dont talk bad about BCD! The truth is, its different for eveyone, when i first got it i tried a million ways to get up and running, (many sugestions in the forum) but it seems that what works for one person (computer) doesnt seem to work for others. if you have it/want it you will have to spend a lot of time playing around with many many settings options/posibilities until you find the one that will work with your computer. I currently have it working flawlessly on a windos xp system (exept for the mic) im now trying to do the same on a Vista system but im having minor glitches. (takes a long time to load vdj when BCD is hooked up, some songs are unscratchable)
geposted Sat 27 Oct 07 @ 7:43 pm
true. I have the bcd and its a mian part of my rig. Im even using its soundcard and its totally stable! However with some laptops, no matter what you do(change IRQs, do all the xp tweaks) you will not be able to get it to work with its soundcard. It will work on alot of pcs, but there are probably alot in which it doesn't work as well.
geposted Sat 27 Oct 07 @ 8:04 pm
