Why is it when I record a mix, choose split files at cross fade and burn it to a cd, that I have a pause in between songs?
geposted Sat 27 Oct 07 @ 7:04 pm
we would be accurate in diagnosing your problem if you told wich version of vdj you have.
geposted Sat 27 Oct 07 @ 7:26 pm
Probably because you've chosen to split the files. I would imagine the pause you are getting is the split.
Gary
Gary
geposted Sat 27 Oct 07 @ 7:28 pm
It depends what your burning program your using, I use Nero, and there's an option to have no pauses in between tracks, it works for me
geposted Sat 27 Oct 07 @ 7:52 pm
