I currently have a dual boot system on my laptop. The laptop has 2 internal drives so i have XP installed on one and Vista on the other.
XP was initially used for VDJ, but i'm now happy using Vista for VDJ and so the XP has become redundant and just taking up disk space.
I like having the dual boot system, 1 for my personal use and 1 for VDJ.
What i want to know, is there any reason why i can't have dual boot with 2 copies of vista on each hard drive, 1 for personal use and 1 for VDJ?
I was planning on using Vista Boot Pro to do this and start from scratch.
Is there any reason why 2 versions of the same OS shouldn't be installed as a dual boot and will it work?
Gary
Gary
geposted Sun 28 Oct 07 @ 3:13 pm
no there isnt , just be sure to install on seprate partitions
you may need to manualy edit the boot.ini file to remove the reference to xp from the startup list however :)
geposted Sun 28 Oct 07 @ 3:56 pm
Cheers Simon,
I was going to start from fresh. Formatting all the drives and using Vista Boot Pro.
Gary
Gary
geposted Sun 28 Oct 07 @ 5:02 pm
By the way, i keep getting a problem with something called ffdshow.
I think its a codec. Not sure where i got it or why. Can anyone tell me what its used for, if i need it or what software i might have installed if for? Its baffling me.
Gary
Gary
geposted Sun 28 Oct 07 @ 5:23 pm
its a codec for avis and some mpgs
used usualy for dvd playing and or ripping
geposted Sun 28 Oct 07 @ 7:56 pm
