Checked for previous post on this matter - didn't find any. Hope I'm not repeating info.
Last night (Saturday 10/27/2007) the city of San Antonio Texas USA was celebrating Halloween. I was Using Virtual DJ 5.0 rev.4 playing video and mp3’s and the program is running stable with no glitches.
Suddenly at ~1:00 AM the dreaded SMILEY FACE fatal error in the middle of an mp3 – Clicked on smiley face – VDJ completely shut down.
I restarted VDJ and finished the night without a problem.
This year, Daylight Savings time change is not supposed to occur until the night of November 3, however it used to change this very Saturday night. I went to check my daily desktop and no Automatic time change had occurred (probably from MS’s Service packs). Checked my gig machine and Bingo – time change had occurred (assuming took place @ ~ 1 AM - time smiley face showed it's dreaded face).
I’m not sure if this would cause the Program’s Smiley Face to come on because VDJ has a Clock on it (the good guys from VDJ can tell us for sure), but I now have changed my Daylight Savings time automatic option to the following:
Start > Control Panel > Date and Time > Time Zone (tab) > Uncheck “Automatically adjust for daylight saving changes”.
Since this year Daylight Savings is supposed to occur on Saturday night of NOVEMBER 3, I would suggest to my fellow VDJ’s to make the above change before then.
Hopefully this will save some people some headaches and some bruised egos. lol
PEACE
Diamond G
PEACE
Diamond G
geposted Sun 28 Oct 07 @ 5:53 pm
I've been on the fence oabout this setting because of the changes, too. Sorry to hear that it caused a problem for you, I think I'll follow suit. Thanks for posting ;)
geposted Sun 28 Oct 07 @ 6:14 pm
Daylight saving time in the UK was this morning at 2am. I worked right through it without any problems, just letting you know in case it helps anyone.
Gary
Gary
geposted Sun 28 Oct 07 @ 7:15 pm
Same here, didn't even get a pop-up window off XP telling me the time had changed, all went fine.
geposted Sun 28 Oct 07 @ 7:56 pm
